outa gas
Jmai22, I'm taking it (since we are in the first gen gs forum) that you have a gs300!!?? I want to do that lextech mod that you did, but I'm confused on what they can do for the gs model. The way I have taken the info that they have posted on their website is that you can only have bright red or bright amber because of the red bar. I also see that you noted on your thread that you have white on blue SC needles, so they just swapped the gs needles for those? Thanks....Lex1
Did you have to send in the whole cluster? And how much did they charge ya? Thanks Jmai....Lex1
https://www.clublexus.com/forums/sho...hreadid=120661
btw, those of you who are planning to get this done expect the following,
1. Your temp needle will not go up to the half mark anymore, it will only go up to about the 2nd line. so now the 2nd line is your normal temp.
2. Your Gas needle will now always sink to the bottom when you turn off the engine, it will not stay at the same place as before you shut off the engine. I'm not exactly sure how accurate the gas needle is, but so far so good, the gas light comes on at the right time still.
3. the speedo and tech are still running perfectly correct.
the needle problem was brought up in the past the answer to the problem was that the weight of the new needles make them do that.
So, if you just had the cluster repaired and didn't get custom needles that weigh more it would all work like before (gas and temp needle)? If mine breaks I just want it to light up like stock...yours looks cool, though.
also he says on the website that the reason why you have to send it in and its soo hard is because of calibration, but if he calibrated that why is my temp needle doing this?
O. L. T.
07-02-04 10:35 PM
O. L. T.
GS - 1st Gen (1993-1997)
12
04-07-04 05:20 PM
