1st gen gs300 w/ gte swap
Old 06-16-04 | 11:01 PM
stocksc300's Avatar
stocksc300
Default 1st gen gs300 w/ gte swap
anybody here has a 1st gen gs300 with a gte swap? i really want to see some pix of the engine bay,
Old 06-17-04 | 08:27 AM
Epik's Avatar
Epik
What part of SC are you from? I have a 93 GS300 that will be turbo soon, but I'm not just swapping in the 2jzgte motor, it will be a big single. I'm in Myrtle Beach.
Old 06-18-04 | 12:00 AM
wayne's Avatar
wayne
Hope this helps.
Old 06-18-04 | 06:53 PM
stocksc300's Avatar
stocksc300
hey epik, is this jeff this is sonny i am in columbia sc. iam doin a gte swap, the only question is where do i cut on the fender side to install the stock supra intercooler?
Attached Thumbnails 1st gen gs300 w/ gte swap-gs-300-gte-swap-055.jpg
Old 06-19-04 | 03:02 AM
hotmachine's Avatar
hotmachine
I'll have to find pics of the engine bay but this was one of the meanest pics I've taken before...
Old 06-19-04 | 09:57 AM
Epik's Avatar
Epik
No idea Sonny. I'll be doing a fmic with 3" piping. I would asume it is in the area behind the passenger headlight. It looks like an indent there that would be punched out in the Aristo to run the charge piping thru.
Post some more pics of your car.. is that silver Volks on the front I see? How far along in the swap are you? Are you using the Supra A/T?
I havent touched mine yet. In the planning stages right now, but I have had the GTE motorset for months.
Good luck.. I'll be getting into mine soon.. but not soon enough.. need boost
Old 06-19-04 | 12:34 PM
suprawhite's Avatar
suprawhite
Not sure this will help
Attached Thumbnails 1st gen gs300 w/ gte swap-aristo01.jpg
Old 06-19-04 | 04:22 PM
johnee78's Avatar
johnee78
Default the stock IC goes....
On the passenger side inside fender...If you look at the passenger inner fender you will see vents..The intercooler goes in the open area in there..The piping is ran through the firewall on the upper inside of the fender were a factory harness is ran through, the hole simply needs to be made bigger..Thats for the upper piping and the lower piping, you need to make a hole for the piping to exit..A hole-saw can be used to make the hole. Hope this helps...
Old 06-19-04 | 09:08 PM
BRAKATK's Avatar
BRAKATK
Default Some day
These pics are great. Someday maybe......
Old 06-19-04 | 11:02 PM
stocksc300's Avatar
stocksc300
thanks for the help guys, ill be done with mine pretty soon. i will take more pix when iam done
Attached Thumbnails 1st gen gs300 w/ gte swap-gs-300-gte-swap-01.jpg
Old 03-01-06 | 12:24 PM
biglex's Avatar
biglex
where did u get that intercooler i'm looking for one
94Silver
Florida Lexus Club
09-23-12 03:31 PM
StarkoS14
Performance
13
01-30-10 01:39 PM
gs4play
Performance
04-28-09 07:46 AM
happypanda
Performance
34
11-23-05 10:02 AM
got_trd
Performance
08-09-05 06:31 PM
