RPM meter light fading!?!
What's up guys............I've noticed that my rpm meter light is fading? Does this mean i have to change it out? Can i change it out? Or is there another solution i can do?
are you talking about the needle itself or the backrounnd, if its the backround yes you can do it yourself for about 2-3 bucks a bulb. if its the needle then you will have to switch it out which is expensive.
thanks!
Contact "OLT", he is a mod on these boards and sells the needles. The only other way to fix it is to buy the whole instrument cluster from Lexus, which costs big $$$.
Forum Administrator
Click here to go to Lextech's website, lextech.org You can contact him on CL via L.L.S. or just use the contact on his website
Originally posted by bmoon_007
Well the background is more dim at the 5 and 6k rpm's, but yes it is the needle and i kinda figured that!
thanks!
thanks!
$13 bucks a pop for these.
OLT sells the background bulbs for $20. I don't know if that's for the set or for each, but If it's for the set, it would be a good idea to replace them all at one time so that you don't have to go through the hastle of taking your dash apart when another bulb fails.
mr29rose
06-09-07 06:57 AM
