lowering gs300 on 20' rims
hey everybody i have anough money saved for a set of rims with tires and springs and shocks..im going with 20x8.5 rim but i was wondering what sizetires should i go with...i was thinkin about getting 255x35x20zr tires all the way around but i worried about rubbing when i lower my car....you think ill have an issue with rubbing if i just got with the eibach prokit that owers the car 1.25 inches??and what shock should i get?? and if you guys have pics of your lexus on dubs id like to check it out...thanks for checking out my thread....and i appreciate the help
Former Sponsor
I used to have a 96 GS300 the car had:
20x8.5" Dronell CA-05
35mm offset
255/35-20 Falken GRB fk451
INTRAX 1.75" springs (settled to about a 1.9)
KYB Struts
You will have no problems with the 255 all around. I will say this though, it will look a little better with a 245 in the front. i tried it with my first gen (switched rims with someone for a day) and it looked better. The only rubbing I ever had was a minor touch of the plastic when backing up at full lock.
Here are a few pics, good luck
35mm offset
KYB Struts
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
dammm ya your cars are lookiinnnnn cllllleeeeeeaaaaannnnnnn!! thanks for the replys i guess imma go with a lower drop than 1.25 in....what springs should i go with??eibach sportlines??hey LEXUS4JESS i like your headlights what kind and where did you get them??or did you midify them youtself???lookinn gooodddd
Former Sponsor
I had the Intrax on mine, and the ride wasnt bad, softer than my current coilovers (I'm alot lower on my coils though)
Offhand, I'm not sure what other springs are availible. PM SUPRATRD, and ask him what he can get for you, he is a parts dealer for ClubLexus.
My humble opinion, with 20s on a 1st gen, more than 1.25 is needed.
here is the brackets I used.Make's it easy to do.
thanks alot for the walk through and the pics ill let you know when i try that mod.....so what springs and shocks should i get???what springs drop it the most???thanks again for the help
O.C. Lucky Strike Fanatic
Here is a picture of my car on tein cs coilovers, its really low.. However, I used to have eibach springs and they were not good enough for me, hence I went the coilover route. If you are planning on getting springs, make sure you get tanabe as those will lower your car the most. Check out the suspension link on my website for more info about the springs available for our cars as well as shocks.
-Bryan
-Bryan
hey lexaristo what kind of headlights are those??i need a pair like that it will make the car look so much cleaner..whats the cheapest coilovers out there that lower it the most??or what springs lower the car most??and what sprigs should i go with??sorry if it doesnt make sence i just woke up..lol...thanks for the help
Headlights are stock and have been cleared out on the corners. I also added JDM fiber glass eyelids to them as well.
The cheapest coilovers are the TEIN HA and the JIC SF1's. They can be had for under $1,000, but the only problem is that they wear off quick and you will bottom out.
Tanabe will lower the most without sacrificing comfort, however Intrax springs are known to sag the most and will lower the car the most. Intrax offer a veyr bumpy ride.
The only shocks available for our cars that are readily available are the KYB GR2 shocks.
Bryan
thanks alot for the advise....so intrax sucks in other words....how low do tanabes lower your car??and eibach sportlines lower your car 1.8 inches right??out of those 2 which one will you go with??and where can i find those shocks for a good price??thanks agian for the help!!!!
