Another screw on the grill wont come off...
O.C. Lucky Strike Fanatic
I decided to take off the whole grill assembly since I am going to repaint the whole thing glossy black. I took off the right side with no problems, but when I went over to the left side, that was where all the problems began. I turned the nut and it just would not come off the screw. The screw and nut would turn at the same time. I went to buy a dremel and I will cut off the screw as that is my only resort.
What do you guys think I should do? thanks
AS YOU UNSCREW IT ,PULL BACK ON THE GRILL SO THERE IS PRESURE IN TH BOLT.It should work.keep us posted.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Try holding the bolt with vise grips,just the tip.with a wrench turn the nut.
I do this when screws strip.
