whats the easiest way to change the Foglights bulbs?
1. pry/pop off plastic screw covers (do from the top of plastic)
2. remove 2 screws (philips head screwdriver required)
3. pull out foglight from inner/screw side
4. twist off bulb cover (counter clockwise)
5. undo latch on bulb
6. disconnect bulb from h3 harness (might be under a sheath covering)
reverse steps for re-install. careful not to touch the bulb with your bare hands.
LS430Owner
01-19-13 07:51 AM
