noisy power steering
Yesterday my car started to make that squeling noise we all hate. it only happens at low rpm while turning the steering wheel. i just filled up the power steering fluid because that was kind of low but the noise is still there. does this mean my power steering is about to go out?? what can i do to fix this problem?
same thing happened to me a few months ago. i kept it filled with fluid but it kept squeaking. Eventually the squeak became worse, more like a rubbing sound. Anyway, it only happens when i first start the car at low speeds and ecspecially on tight corners. The mechanic said air is getting into the steering column and it would need replacing. Estimated parts and labor is 800. I just cant justify putting that much into the car so ive decided to sell it. hope this isnt a common problem.
The Green Grundel
They told me it could be air in the steering but i went somewhere else and they said it was the powersteering pump so i got a new one installed for like $528 and the sound never came back agian.
Fluid loss, but where is the power steering leak? That is where the air is getting in, right? Maybe it just looks like it is coming from the column. It could be dripping onto the column, you know? My Lexus dealer made that mistake; it was actually coolant leak.
I would suspect the column last, nobody on here has had it go out as far as I know. Bunch of people have burned up their PS pump, though. And you know those hoses will spring leaks, especially on a 10 year old car.
the column was a consideration. I'm not really sure, i had 3 places look at it and only one could even find some sort of problem. Either way, it seens like its gonna cost alot.
Well if your power steering system has never had a flush&fill you could see if that fixes the problem. That shouldn't be expensive and it is worth doing even if the pump eventually gives out.
O.C. Lucky Strike Fanatic
I took my car for some hard driving today after setting the stiffness setting on my coilovers to the stiffest. I hear that noise when i turn and then it would go away. Any ideas why it would be noisy and then would quiet down a few minutes later.
thanks
thanks
bout a month ago i replaced my PS pump because it wasn't pumpin. I ordered one from overnightparts.com and they sent me one with all plastic red pieces shattered to pieces and completely greasy,
yea, big thumbs down to that.
When we replaced the pump, it was super quiet but with the new one, it makes a lot of noise, more than the engine. Doesn't sound like a bad sound but i certainly don't want to hear it. We UNFORTUANTLY put regular (super america) ATFluid
because i forgot to buy it in advance.
Also, fluid leaks out of the top from the cap, and the fluid leve is a tad bit full
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Originally Posted by turbogs300
It could be a bad pump, was it new or remanufactured, rebuilt or used? Also did you check to see if the steering rack screen filter in the inlet from the pump was clogged or has gunk in it? ATF IS atf as long as it's clean it shouldn't make too much of a difference. Are you sure it's coming from the pump and not the tensioner? ![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
realsync1
07-07-18 06:54 PM
Och
GS - 1st Gen (1993-1997)
07-31-03 09:23 PM
