My new brakes.
Old 12-11-04 | 01:17 AM
Wald GS's Avatar
Wald GS
O.C. Lucky Strike Fanatic
Default My new brakes.
These are the R1concepts.com Premium rotors (not your ebay special) and were a special order because of the stronger casting process/quality. They also have a electric black paint which will not come off and prevents rust.
They were customized to my liking which was dimpled and slotted. I also have a set of r1concepts stainless steel brakelines and 2 sets of axxis/pbr metal master brakepads.
I will install these this week and provide you guys with some feedback.
If interested contact Martin at r1concepts.com and tell him "Bryan with the Lexus sent you" he'll hook you up.
Old 12-11-04 | 09:04 AM
Seize's Avatar
Seize
Loves Snickerdoodles!
Default ...
Very nice, I especially like the black rotor hats....just curious - what are the specs, front and rear sizes? Oh and most importantly how much?
Old 12-12-04 | 10:52 PM
Wald GS's Avatar
Wald GS
Here they are installed along with the stainless steel brakelines. After breaking them in, stopping has increased dramatically. I can feel the pads bite into the rotor without brake fad as a result of the new brakelines.
Seize, it depends on the type of rotor you want to determine the price.
Old 12-13-04 | 10:48 AM
lexus4jess's Avatar
lexus4jess
How come the your rotors are dimpled only ,not all the way throw like mine???All the rotors that I've seen go throw.
What's the difference?
Old 12-13-04 | 11:26 AM
Wald GS's Avatar
Wald GS
I didn't want cross drilled because it has a tendancy to crack. Porsches started the dimpled craze and they are more for daily driving/ race oriented. Cross drilled are for pure racing because when you race, your brakes are under intense heat and need cooling.
Old 12-13-04 | 11:33 AM
gompka's Avatar
gompka
yea the dimpled are the way to go imo. Epik uses them too. They still trap gasses and remove them from around the caliper.
Old 12-13-04 | 05:06 PM
kts_GS3's Avatar
kts_GS3
Hey Bryan, your new brakes looks very nice. Let me know how they feel in a couple of months. I'm thinking about replacing my rotors too when I replace my brake pads. My 120,000 miles major service is coming up so I think I'll probably do it then.
Old 12-13-04 | 06:42 PM
LB Lex's Avatar
LB Lex
Looks really good Bryan I like the painted rotor hats, I hate it when the stock rotor hats rust, they're really an eyesore. Now you don't have to worry about that, all I did was paint them with silver Rustoleum, works pretty well.
Are those stock size and are you running the stock calipers?
Old 12-13-04 | 09:26 PM
Wald GS's Avatar
Wald GS
Thanks Eric! Those came electric black finished to prevent the rust and other discoloration. My old rotors had rust but no one could see. heheh
Yep, those are my stock calipers. thanks for your great support as usual!
Thanks alot Kevin!
So far they feel really good! When I brake, I can feel them bite. It will look even better on your car since you have spoke rims!
Bryan
Old 12-14-04 | 12:20 PM
rpx13's Avatar
rpx13
looks great!!!....thinking of getting some rotors too....i'll prob wait till I hit 100k....
Old 12-14-04 | 08:23 PM
Wald GS's Avatar
Wald GS
Default Re: ...
The size is stock. The cost was 550.00 since I went with the whole package deal of 4 rotors(400), brakelines(100), and 2 sets of pads(100). It would of been 600 if I had purchased separately. Hope that helps.
Old 12-15-04 | 02:41 PM
lexus4jess's Avatar
lexus4jess
What gases?You mean, brake dustand debris.right?cuz the dimples work the same as the slots.hehe.You just pay more for something that works the same as drilled.But you do get the Black paint.(pretty). it's all good.
Old 12-15-04 | 03:17 PM
LB Lex's Avatar
LB Lex
What gases?You mean, brake dustand debris.right?.
When you brake there are gases created by the high heat and the friction material that reduces brake performance. This is noticeable mostly if you drive hard because the brakes get hot real fast after braking hard a few times.
I'm not sure which is better, but I would think that slotted rotors are better than dimpled because the slots allow the gas to escape while the slots give the gas a little room to expand. As Bryan said though, drilled rotors probably are better at letting the gases escape but they tend to weaken the rotors.
For street use, Bryan got a good compromise by getting dimpled and slotted rotors
Old 12-15-04 | 08:47 PM
lexus4jess's Avatar
lexus4jess
You mean the steam from the pads are gases?I thought it was heat.
Old 12-15-04 | 09:46 PM
Wald GS's Avatar
Wald GS
Dimpled does not crack as easily as cross drilled. Either way, you pay for what you get.
Quick Reply: My new brakes.
