Wheel studs broke off...how to fix
My wheel studs broke off, causing my rim to fall off while driving/turning...not fun.
Just wondering how I go about fixing this?
Originally Posted by morris
More importantly why did this happen and how can you prevent it from happening again, I mean does over torquing cause it or what?
The One
I think it happened to me because i was jipped on lug nuts when I got the car and the back tire had only 3 nuts holding the tire on.
As for what to do now, what turbogs300 said.
you might not need to press on
you can zip thenm on if you
access to an air gun
it will pull the stud right thu
have to go to work but ill explain in more deatail later
but its easy
but its easy
If you were driving around with two lug nuts missing for a while and one of the studs eventually broke, I would change them all because they are all probably weakened from missing two lug nuts. This is just to be safe but I think it's worth changing them all because the other ones might break and cause a big accident. Plus, you'll save money on labor if you get them all changed at the same time.
EddierRo
04-01-09 07:17 PM
chubby
CL of Southern California
07-19-07 01:30 AM
