Shift Knob loose!
Shift **** loose!
What's up guys, well i was in Shreveport this weekend (didn't do to good, down $600 on the craps table ) anywho. When i received my car back from valet, my shift **** was loose, i think them d@mn valet kids jacked it up! Well now it feels funny and loose. Has anybody had this problem before and how can i fix it?
Thanks in advance guys!
Originally Posted by turbogs300
If it's a GS3 remove cover on front of shifter and tighter the 2 screws.
Originally Posted by lexxtasy
So what do you have to do exactly guys if you feel your gear shifter is loose? I mean which screws need to be tightened and what plate needs to be removed?
Thanks
Thanks
alright guys, well i found out that it is broken from the screws and wondering where can i buy another. Hopefully this d@mn super glue helps and if not, do i have to replace the whole shift **** or can i just buy the piece where the screws go!?!
thanks guys!
thanks guys!
i had this happen before and super glue will not hold it. Everytime you shift gears it will break again, also you will have a hard time putting the car in park. just buy another look on e-bay i see them once in a while.
Actually Jmai22 I was refering to the looseness I feel sometimes on the road while driving about 60-80km/h you feel a little shimmy in the gearshifter but which goes away after 80km could it be related to the tightening procedure you mentioned above?
thanks
thanks
Blue98Gs3
01-18-04 11:59 AM
