Check eng light
Old 03-04-05, 09:40 AM
twojayzee
twojayzee's Avatar
Default Check eng light
This is a basic question but I couldnt find it in the search.
My 1994 Gs 300 is randomly throwing the cel on cold mornings. I want to pull the code.
Are these OBD1 or OBD II ? and where is the plug to pull codes and where can I find a list of codes other than the dealer etc....
Thanks !
Old 03-04-05, 09:54 AM
johnee78
johnee78's Avatar
Thanks !
Get a paper clip or a jumper wire and under the hood you will a small black box that says "diagnosis" directly behind the powersteering resevoir..Open it up and jump Te1 and e1 and then go inside your car and turn the ingition on but dont start the car..The CEL light will blink and pause and then blink again..For example if your CEL blinks 3 times and pauses and then blinks 1 and pauses and starts the same code over again it means that your throwing a code 31..Do this and post what code it is throwing and I will give you the diagnosis for the code..Hope this helps..
Old 03-04-05, 10:09 AM
twojayzee
twojayzee's Avatar
alright thanks, just like the ol' hondas then. Is there a place online that has the codes ?
Otherwise ill pull it and post it up.
Thank you,
James
Old 03-04-05, 10:11 AM
johnee78
johnee78's Avatar
Thank you,
James
No problem, just post up what you get and ill tell you what it is..
Old 03-04-05, 10:25 AM
link13
link13's Avatar
Hi EG8 - the following site has the codes:
http://www.troublecodes.net/Lexus/
Old 03-04-05, 12:23 PM
turbogs300
turbogs300's Avatar
Cool
It's OBD1 and more than likely it's an oxygen sensor if the car has around 100,000 miles and they've not been changed, There are 3 of them
Old 03-04-05, 12:51 PM
Jmai22
Jmai22's Avatar
I had the engine check light on and my problems were the famous EGR valve and TPS sensor. I actually have an extra TPS sensor because i bought one, but when i went to my mechanic he also had one and told me to return mine, but i couldn't because dealers won't let you return electronic stuff. so if anyone needs a brand new TPS sensor PM me.
Old 03-07-05, 09:04 PM
JENS LEX
JENS LEX's Avatar
Default touble code 17
HELLO!
I'm a new owner of a 1993 gs lexus! yea!
But I have a touble code 17 ............. What is that about ???
and how do I fix it????
??? whats cmp 1 ?????????
need help???
Old 03-07-05, 10:47 PM
turbogs300
turbogs300's Avatar
Cool
There is no code 17, doublecheck it!
Old 03-08-05, 09:49 AM
link13
link13's Avatar
There is a code 17. It says "CMP 1" which seems very ominous.
Old 03-10-05, 12:26 AM
JENS LEX
JENS LEX's Avatar
Default ?????
So what does that mean cmp 1 ???????
Old 03-10-05, 12:39 AM
turbogs300
turbogs300's Avatar
Cool
NO THERE IS NOT!!!
Old 03-10-05, 07:45 AM
Pianoman72
Pianoman72's Avatar
I got the manual, too, and it doesn't list a code 17, as turbo said. Just try pulling the code again.
Old 03-10-05, 09:31 AM
link13
link13's Avatar
Look at the list for without OBD2 here http://www.troublecodes.net/Lexus/
It shows a 17. Sorry for trying to be helpful. It won't happen again.
Old 03-10-05, 10:26 AM
turbogs300
turbogs300's Avatar
Cool
It's wrong or it's for a different model lexus as pianoman and I are telling you. There is a code 71, which is one I've been seeing come up frequently on the 1st gen GS3's.
Quick Reply: Check eng light
