lowering springs questions
Originally Posted by LexAristo
Start placing your order for new shocks because you will need to be replacing them every 8 months.
Originally Posted by dlexmon
You mean with the Tanabe DF210 springs and new KYB shock setup, the shocks only last 8 months?
Originally Posted by EG8
If you chop the DF210 springs. The KYB's are made for X amount of travel and within certain parameters. Once you exceed these the shock will not function properly. It may overheat, blow seals, bottom out and bend which will then lead to blown seals etc...
Thanks for the info.
i thought that any springs would need replacing in about a year. ive even heard that the eibachs need a replacement every year. is this true? if not then im for sure getting some.
Originally Posted by MyScRuNmIa
a just to give you a heads up,i tryed to put 295/30/19 an it wouldent fit your gona have to do alot more than roll the fenders
I have a 275 on now and theres almost three inches of room on the inside before the rim or tire would come close the the strut or any other moving part.
O.C. Lucky Strike Fanatic
