26mpg WOW!!!
Old 05-24-05 | 01:55 PM
gserep1's Avatar
gserep1
Default Elevation Is The Answer
Those that travel in higher elevations get significantly better gas mileage. It is all done with the computer.
In higher elevations, the O2 sensors detect less oxygen in the atmosphere, so in order to prevent a "RICH" fuel mixture, the sensors cause the computer to "lean" out the mixture at the injectors.
So less gas, less air equals less power, but MORE mileage. This is why lower octane is acceptable in the mountains., but causes a ping at sea level.
Old 05-24-05 | 04:40 PM
sillbeer's Avatar
sillbeer
Does it cause a ping at sea level? Do you know that for fact? I'm asking because the same year automatic NA supra only uses regular gas. Same engine compression, HP output, TQ, etc..... Whats different? I asked my father this. He's and ASE certified mechanic and he said almost always if the owners manual says something then it's for a reason. Him nore I could come up with why. I don't know.
-Destin
Old 05-24-05 | 08:10 PM
turbogs300's Avatar
turbogs300
Cool
-Destin
I checked every NA Automatic supra produced beween 93-97 and every one was 10:1 C/R and used PREMIUM FUEL. Your info seems to be wrong.
Old 05-24-05 | 08:46 PM
sillbeer's Avatar
sillbeer
Your probably right. I was going off information I got second hand. I couldn't find anything that said different than premium.
-Destin
Old 05-24-05 | 09:26 PM
lexus4jess's Avatar
lexus4jess
good info.
Old 05-28-05 | 12:41 PM
LexTE's Avatar
LexTE
Originally Posted by SuprRunner
Well, after driving it for awhile after I got back from my road trip, I now back down to about 20. Still better than my previous 17mpg. I am running a semi synthetic 20-50. I won't run full syntetic, especially with 230,000 miles.
Off-topic, but I was just wondering how many times have you changed the timing belt? At what mileage did you do so, if you did. 230K miles is awesome. Thanks!
Old 05-28-05 | 12:54 PM
PuppyDawg's Avatar
PuppyDawg
Originally Posted by lexus4jess
dead weight on your cars will reduces the mileage.boom box ,amps,rims will give you less mile.
"example" with my stock rims I got about 300 mile.with the 20"rims I had, I got about 220 mile.to the tank.
so true....even your ground effects/spoiler or you having the windows down must be taken into consideration when you're trying to get the most mpg...
Old 05-31-05 | 09:48 AM
SuprRunner's Avatar
SuprRunner
I just bought the car with 220K. I don't know the last time it was changed. I should probably take a look at it.
Old 05-31-05 | 01:59 PM
robloc93's Avatar
robloc93
Thanks for the info
tpham32
IS F (2008-2014)
36
09-27-16 11:01 PM
Rdrcr
08-08-16 08:51 AM
djrabbi
11-11-15 06:37 PM
Compthis
IS F (2008-2014)
29
07-02-14 08:38 PM
aznserpent
IS - 1st Gen (2001-2005)
11-02-02 11:42 AM
Quick Reply: 26mpg WOW!!!
