cruise control
so i finally tried out the cruise control, i hit the button and the light on the dash lit up, then i treid to set it and nothing happened, no matter what i did i couldn't get it to work, is there a way to fix this?
The way I set mine, if I recall correctly, is by getting at my desired speed, press the button to make the cruise control light come on, then I press from the top of the switch so that I'm pressing toward the floor which sets it. I'm not questioning your method, but that's how mine works. If you have tried it this way, it may be the cruise control box itself. I'm sure others will chime in with better details.
im gonna mess around w/ it tomorrow to see if i can get it to work, hopefully it will just be the problem of me being stupid and doing something wrong
first of all the green light has to be on (obviously), second of all you have to be going at least 25-30 mph. push the level down towards the floor to set initial speed. then from there if you bring the arm up it makes the car go faster, and if you bring the bar down it slows down the car. and to cancel anytime just press it towards your body or tap the breaks. if you press the gas at any time it will go faster but will just go back to the cruise set speed once you let go of the gas. finally to resume your previous speed setting just press up once and the car will go back to the speed it was at before you stepped on the breaks or canceled.
