Wind Noise and part replacement
Has any one had there window frame (driver side) molding replaced. I have almost enough of that wind noise. Is it best to have a Body shop do or a dealership .... Thanks ,
( Where did you by the part? )
my car is at a body shop right now getting this fixed. im not sure exactly how much it is yet since my dad took it in while i was at work, but i think it was a few hundred. mine was getting pretty bad though. started as kind of a small gap and just kept growing
check to see if the top of the door is lined up if ts bent a little it will not let the door seal properly. I think this is a pretty common problem. Most of the gs's ive been in have noise from the doors at some point
