Changing Air Condioning Filter on a GS300
Regarding changing the Air Condioning Filter on a GS 300. I believe the filter is located behind the glove box, but I don't see an easy way to get to that cover. What is the easiest way to get to that filter and replace it?
Thanks, Marty Leeke
Thanks, Marty Leeke
Thanks, Marty Leeke
Thanks, Marty Leeke
It's under the glove box. Stick your head under there and look up - you should see one phillips head screw. Unscrew that and remove the cover. There probably won't be an air filter in there but if there is bring it with you so you buy the right size.
If you run a search I took a picture of the area and posted it.
Bliggity
GX - 1st Gen (2003-2009)
12-30-09 11:58 PM
