just change spark plugs and check engine lights comes on
can someone help me with this problem........ i just change my spark plugs on my 93 gs300 when i drive the check engine lights up ..... and when i shut it off the car and start it up again it would just shut off ..... it will just start for a second and just shut off .......... sometimes it will start when i start it but the check engine would be on when i step on the gas while park the rpm goes to two and it will just shut off again.... does anyone know what the problem is could it be one of the sensor ...... thanks
I'm not familar with the First Gen GS. But they have distributors correct? Check your firing order to see if you plugged it up correctly.
This should be your firing Order
From Cylinder 1 - 6
1, 5, 3, 6, 2, 4
From Cylinder 1 - 6
1, 5, 3, 6, 2, 4
From Cylinder 1 - 6
1, 5, 3, 6, 2, 4
From Cylinder 1 - 6
1, 5, 3, 6, 2, 4
checked the wires thats is connect to the distributor cap ?
