Rotors????
For those of you that have upgraded your rotors to drilled/slotted, what brand did you go with, and how do you like them?
I have been looking on the internet and I see brands like Brembo (of course), R1 concepts, Trinet, Stop tech, etc. I am just not familiar with the reputation of a lot of these brands, so I would appreciate any advise that can be given.
question is , how much do you want to spend. how agressive to do you drive , what kind of pads do you intend on running
my own research and opinion is unless you are doing a bbk , dont get crossdrilled one piece rotors.. in bbk most use 2 piece floating rotor design which will help prevent warpage... in a 1 piece design its very very easy to warp these things because of heat.. brembo makes a sport rotor called brembo sport which come either slotted (which i highly recc) or drilled but not both.. beware of many imitations of brembo stuff out there , the real deal has a goldish hue in color on them, the inferior ones have a zinc plating ..
rotora makes a great rotor and projectmu.. but again answer the top 3 questions first them you can put together the right mix
sp rotors
www.raceshopper.com
and hawk HPS pads
no drilling if you plan on tracking otherwise get what you want
www.raceshopper.com
and hawk HPS pads
rsk121
RC - 1st Gen (2015-present)
04-19-19 04:15 PM
