2JZGTE Swap..........
Old 11-30-05 | 08:04 PM
jdmjunk's Avatar
jdmjunk
Default 2JZGTE Swap..........
I am new to the forum and have explored the "Search" option of the forum, but really cant find any info on doing the swap.
I have a 1995 GS300 bone stock, and also have a 2JZGTE Clip sitting here with the engine out already, and was looking things over but still had some questions........
Is the harness from the JDM set-up Plug and Play?
-if not what needs to be done or what are the differances?
What things will I have to look out for while doing the swap?
I have done many swaps (Sr20det S13 ,VG30DETT na-tt conversion, Honda swaps) before so I do know how to work on cars..........but never on a toyota, this is my first one.
Thanks .....any info would be helpfull
Old 11-30-05 | 08:48 PM
nyARISTO's Avatar
nyARISTO
Sunroof Surfer
what clip is it from the aristo clip or a supra???
Old 11-30-05 | 08:51 PM
nyARISTO's Avatar
nyARISTO
Sunroof Surfer
big diff. if its from 2 diff. cars......... were they are easy swaps anyways for the aristo jdm u have to push back the pass firewall because of the rear turbo and motor sits lil close to the firwalls too
Old 11-30-05 | 09:10 PM
Epik's Avatar
Epik
also if the clip or the engine is from a Supra you will need to swap the oil pan and sump to an Aristo one. mounts are different also.. use the stock Lexus GE mounts.
Old 11-30-05 | 09:13 PM
johnee78's Avatar
johnee78
Exclamation
The JDM aristo harness will also have to be extended..It is easier to use a Supra harness..
Old 11-30-05 | 09:28 PM
Epik's Avatar
Epik
easier.. I wouldnt say that. The Supra harness is not plug and play. The JDM harness is just a lengthen it and your done project..
Old 11-30-05 | 09:38 PM
johnee78's Avatar
johnee78
Exclamation
If you use the supra harness you have to use the supra computer..And the supra cpu are easy to come by because most TT owners use stand alones..
Old 11-30-05 | 09:45 PM
Epik's Avatar
Epik
if he has a clip, then he has a jdm ecu. he also has the benefit then of no MAF, the jdm 2jzgte use MAP or Speed density. Most swaps from reputable importers should come with all the accessories (2jzgte has a different PS pump..etc.. ) an ECU and an uncut harness. Make sure to get an igniter as well. Of course all this could be solved by buying a front clip, but then you have to dispose of the leftovers and that can be a pain for some people.
Old 12-01-05 | 04:59 AM
jdmjunk's Avatar
jdmjunk
the clip is from an aristo,
so following has to be done
-make room for the clearance of the rear turbo
-extend the ecu harness.........
how much does it need to extend (harness)?
Old 12-01-05 | 07:25 AM
Tramix's Avatar
Tramix
CL Folding 10,000
Check out this thread
https://www.clublexus.com/forums/sho...ht=aristo+swap
craw tells some details about his swap. I think some info on the ecu is in there
Old 12-01-05 | 10:09 AM
nyARISTO's Avatar
nyARISTO
Sunroof Surfer
that dont clip into the gs's only the aristo harness do ....... check out tramix's thread
Old 12-01-05 | 10:11 AM
nyARISTO's Avatar
nyARISTO
Sunroof Surfer
just 2feet will be enuff more then enuff... make sure u soider those wires and protect them from the turbo's... u should put a shield over the turbo's .... matter of fact they come with the turbo's
Hydro
Performance & Maintenance
02-13-11 07:44 AM
Sag
02-13-10 10:25 AM
tuninghaus
24
03-29-08 09:37 AM
cacrawfo
Performance
141
02-19-07 12:25 PM
