Cel 21
Cel 21
Main Heated Oxygen Sensor Signal (Fr)
When I look at the Header there are 2 O2 Sensors
Are they talking about the front or rear O2 sensor when it gives this code?
21 is the front sensor in the bank closest to the front of the car. You should replace them in sets for better performance as the older they get the slower they react.
Originally Posted by johnee78
So are you saying that the sensors dont have to be bad , but as they get older they dont work as efficiantly?? Would a CEL turn on if this was the case?? Im asking because my car is a 93 with 157,000 miles and Im wondering if I should change them out..
I don't believe the CEL will trigger unless there is a complete failure of the heater or the sensor in the 02 sensor. if you have 157thousand miles and they've never been replaced, I'd replace them. They usually only last or are designed to be replaced around 90 to 100 thousand miles, sometimes much less. If you pull them out more than likely they will be coated with carbon. Yes, as they get older they react less efficiently.
Thanks for the reply..Are they difficult to replace?Do I need to use factory or can I use aftermarket, like bosch for example??
Thanks for the reply again..I always like to run factory parts so I will probably go with the faftory O2 sensors..I live in florida so I am going to soak the bolts holding the sensors with PB blaster , hoping that it will help loosen them up..Ill keep you guys updated if I notice any differences between the old and new sensors..
Originally Posted by Lexus Dawg
Turbogs300, are they expensive to replace? My 95 is around 95K, maybe I should do the same. Who is a good source for the OEM?
02 Sensors
Turbo, thanks for the link to the oxygensensors.com..I want your opinion on whether I should get the denso ones from the site or just get from the dealership??My price difference is only about $40 total..What do you suggest??
StanVanDam
06-01-10 02:13 PM
