Replacing fuel pump
#47
This was about as simple of a job as any car I've worked on. Hope this helps someone.
![](https://www.clublexus.com/forums/members/clarkkent-220344-albums-1993-gs300-14406-picture-back-seat-removed-35813.jpg)
Take the panel off and you'll see cap for the pump. That glue is some sticky stuff. I used a hammer and a putty knife to cut through it. Then used a pry bar to slowly lift it off without bending the panel.
![](https://www.clublexus.com/forums/members/clarkkent-220344-albums-1993-gs300-14406-picture-plate-off-35814.jpg)
In this picture you can actually see the pump down in there. take off those three bolts and the carriage comes right out. japaneezy!
![](https://www.clublexus.com/forums/members/clarkkent-220344-albums-1993-gs300-14406-picture-inside-fuel-tank-35815.jpg)
#48
I think maybe you should look..Remove your back seat and the padding thats behind it.You will see a black plate that is held on with 10mm bolts(I think).Remove this plate and the pump is right there..the picture you posted is the the tank seen from the trunk..Also I have had my 93 gs300 for 5 yrs.. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
