fuel door wont pop
fuel door wont pop
hello everybody
just bought another 93 gs and my fuel door wont pop..Is there a fuse I can check?
I serched and couldnt find anbody with the same problme..thanks for the help
look in your trunk by your fuel door. There should be a thing you can pull to open your fuel door. If you cant find it, take apart your carpeting...it should be there!! Good luck
Originally Posted by YaYAReAGs3
anybody ??I checked it out all wires are coneected but still not poppin
Originally Posted by turbogs300
What, Am I fixing your entire car today?!?!?! Jump the switch in the dash, if no workie still apply power to the actuator in the back and see if that works.
thanks for the advice Ive been using the the cord to pop it but im trying to fix the problem thanks again for the reply
if i had known this sooner i wouldnt have broken the plactic peice that locks it, sand and smooth it and bend the metal flap that keeeps it open slightly. when i need to open it now i just tale my index finger and tap it slightly.
