how do I disable my alarm permently
hey evrybody
I dont have the remote with the button so everytime I open my car with my key the alarm goes off and the car wont start..is there a fuse or something I can disable to make this alarm not work anymore?I did a search and nothing came up with my same problem..thanks for your help im just trying to work out these little bugs
Originally Posted by Tramix
Isn't there a switch on the dash, left of the steering wheel. You can just switch it off. I don't have my key either. It's in a million pieces on my desk.
Whenever I flip that switch the alarm and everything still works and the keyless works too, just when I lock and unlock I dont hear the 1 and 2 beeps. It may be differenet on the pre 96' models. Also, I looked through the manual and all I could find was a fuse for the hazards and the horn. If you want that disabled then its fuse 20 in the fuse box.
In the fuse box your gonna have 4 rows with fuses on them.
The at the top closet to the cab is gonna have 6 Fuses, The next row is gonna have 9, the next row has 1, and the row at the bottom has 2.
If you want to try this just pull the 6th fuse on the 2nd row closest to the cab.
Good luck.
Good luck.
Originally Posted by turbogs300
No! I believe that only turns off the keyless. You'll need to find the disarm wire in the drivers door and ground it.
thanks for your guys help!
Originally Posted by YaYAReAGs3
the alarm only dissables when i unlock with a key from the pass side and when i try to unlock with the key from the drivers side door it goes off
Correct, because the key unlock disarm switch is probably bad or disconnected..
sorry about all these questions..im new to these cars where can I find the dissarm switch?/take off te door panel?
