brake bleed problem 93 gs300, brake light on along with trac light.
I know theres lots of other threads about this issue and i think i am doing the bleeding the right way. OK what i did was changed calipers, rotors all that good stuff so now when it comes to bleed ing the brakes i had one person pump the pedal 3 times and hold it down then while the other person was holding the brake down i closed the bleed valve and the air did come out and brake fluid like shot out so i repeated the same thing till no air came out. Brake feels fine after i did the rear pax and then rear driver side. But i get breake light along with trac light on the instrument panel? now i have no idea cant find anything in the maint manual.. maybe not looking hard enough? If anyone has any ideas let me know please? thanks alot guys.
no i did not bleed either, just bled the brakes. anyways i decided to ake the car for the spin.. and i got half a milfe from my house, the brakes worked perfect. Then, i was waiting at a red light and the brake light came off and a second later the trac light came off so everything is all good now =) thanks for the response!
