Power Steering Pump Leak
Hello, My '93 is leaking power steering fluid around the pump. Besides that the steering is working fine, no noises,easy steering. Without removing the pump I can not pinpoint where the leak is coming from. I know on some cars the seal between the reservoir and the pump can be the culprit. Is this a possibility on this car. I don't want to spend the $$ on a new pump if all I need is an o-ring. Also, is it difficult to remove the pump? Any suggestions appreciated.
Ozzie
Ozzie
Ozzie
Ozzie
I just noticed that the area around the pump is damp with fluid and the fluid level goes down over time. If there are no leaks in the system the fluid level will go down VERY slowly.
hidavi
Performance & Maintenance
06-11-16 10:36 AM
Lsportline43
14
04-03-10 01:31 PM
