DG Trials: the only 1st Gen in this D event!
Old 05-04-06 | 07:22 PM
jmax.garage's Avatar
jmax.garage
Default DG Trials: the only 1st Gen in this D event!
Looks like I am the only Lex owner on this event:
This is my setup, just waiting for some Tein flex coilovers (thanx Eric-rps13):
Wheels are Wedsport Novarys S type 18 8.5F~9.5R +29F +37R
I will post pictures after the coilover installation and during the event! I got free tires also from Ultraperformance.com because i am attending; so stay tuned!!
Excited? THE HECK I AM!!
Old 05-04-06 | 07:49 PM
7Cain's Avatar
7Cain
Default Awesome bro!!!!
You will have a blast, good luck! Looking forward to seeing the suspension. Take it easy, if not, then take it any way you can get it.
Maximum Respect
Old 05-04-06 | 07:57 PM
Abear's Avatar
Abear
CL Folding 200000
Good luck man, have fun!
Old 05-04-06 | 08:14 PM
A/X's Avatar
A/X
goodluck, represent CL!!
Old 05-04-06 | 10:19 PM
Epik's Avatar
Epik
Hell yea Kidzik.. nice pickup on Eric's Tein sus.. Get used to the only Lexus thing.. It's the same with me all the time at DG Trials and SEDA over here.. heck anywhere I go..LOL
Here is a pic from the first of our now weekly local events. This was on April 19th at the Myrtle Beach Speedway, we have full reign to set up courses on the infield.. everyone with a helmet and a rwd car is welcome to come out and drift !!
Old 05-05-06 | 06:07 AM
GS3Admired's Avatar
GS3Admired
hot..
Old 05-05-06 | 09:26 AM
Seize's Avatar
Seize
Loves Snickerdoodles!
Default ...
Nice! Good luck on your run bro
Old 05-05-06 | 09:36 AM
Eric-RPS13-'s Avatar
Eric-RPS13-
the dream of the aristo drift team won't be realized !
(STUPID WRECKS!)
Old 05-05-06 | 12:18 PM
i7kazamay's Avatar
i7kazamay
dang thats awsome what do ppl think when u roll up in a lexus
whats your technique
Old 05-05-06 | 06:24 PM
Epik's Avatar
Epik
Talking to me I guess? Well now that I have power i use the flick to throw it out and the throttle to keep it there..pulsing it just to keep the turbos spooled and the tires spinning. On tight courses, the e- brake comes in a lot, and no it is not easy being on the floor as a pedal. That is changing soon.
Now at this last event with a long entry run I was swinging it back and forth to enter the turn at the proper angle. Example.. it was a right hand long sweeper.. I would leave the start box, as soon as the turbos spooled, flick the wheel to the right, snap back to the left and then to the right again to enter the sweeper to the right. The challenge was to time the initiation to come into the turn at the correct angle and exit in position for the hairpin right hand switch back we made for the next turn, that then ran thru a series of "S's" winding back and forth. I will tell yo this.. weekly events are making a HUGE difference in my consistency.
Old 05-05-06 | 06:57 PM
jmax.garage
my technique is speed and weight balance (feint). since i drift a hachi too (not very lately) I started fiddling with my lexus and would go like to 60 then feint the car about 5 yds before the apex, drop to 2nd and push the gas gradually- I was not using the e-brake because I thought it was imposible... on a stock suspension this really sucks because the car squats BUT you SURE get a lot of smoke and its very 'showy' because the car is too big BUT the exit speed is pretty slow because there is no power to back the weight down and also I don't wanna break the tranny... yet. On tight courses (like the DG trials I am attending) I simply do a 'braking' technique and fiddle with the gears and the power output. You gotta really watch the DB to understand certain terms.
Oh, Epik, how low is your car when in drift setup? also how stiff the struts? alignment? would you share some suspension setup? Thanx!!
Old 05-05-06 | 07:10 PM
Kaiser's Avatar
Kaiser
My car needs a lot more cowbell before I'd enter an event like that. Even then, I'm not sure I'd want to roast a set of tires in 1 event.
Old 05-05-06 | 09:44 PM
jmax.garage
get used tires. i will take min 2 sets. =]
Old 05-06-06 | 11:39 AM
Epik's Avatar
Epik
I am on Racing Logic coilovers, and it's hard to say how low it is compared to stock. All I know is that from the wheel well to the ground is an average of 25" all around.
I run the same setup on the street and my Racing Logics are damper adjustable. 4 full sweep turns on the top of the strut from full soft to full stiff. I'm playing with the settings but right now I'm about 2.5 to 2.75 turns on the front and 3 turns on the rear. I change the damper settings according to course setup occasionally. Too stiff in the front and the car will understeer like a pig.. too soft and it will just body roll.
I'm in the process of designing a big rear sway bar for the car. Mine will be a lot simpler than the stock shaped bar b/c I no longer have a spare tire well to go around.. I can run a straight 90* on each end bar to some spherical bushed endlinks. That and the upcoming 6pt cage will do the job to flatten the car out and keep it that way. Once that is done I'm going to really setup the suspension with corner weight scales and learn to drive it once and for all
Old 05-06-06 | 11:40 AM
Epik's Avatar
Epik
I took 8 rims and tires with me to our last weekly event, not including the good ones i drove in on.
