Engine Running Temp decreaser
I'm in the process of doin a coolant flush right now. I've been recommended Water Wetter to decrease the running tempareture of my engine. Anyone have any experience wit this?? I saw something at NAPA, a blue liquid for 14$$$.
What are some of the benefits of this??
Doesn't work really... I have used it with straight water. Same results... I wouldn't recommend against it... NOT for it... but... it won't hurt... You are better off using a little less coolant and more water for better results. That is the whole trick of water wetter.
The only one I have heard to "work" is evans NPG, that is purple.
a 50/50 mix with a proper ammount of water wetter will do a lot
a blown radiator hose on a track day and luckily a replacement at a nearby parts store + 50/50 and water wetter, the car really did run cooler, the person had an acurate water temp guage.
I didn't personally witness the readings, but an elated, pissing his pants over it, happy friend loves the stuff after that.
Originally Posted by Kaiser
Water Wetter will have nothing to do with your air conditioning.
DaKi3241
04-12-13 11:56 PM
