change head gasket 93 gs300
Old 06-19-06, 01:07 PM
ken8817
ken8817's Avatar
Default change head gasket 93 gs300
can anyone give me info on how to change the head gasket on my 93 gs300 225 000 km? Can't be that difficult or is it? Maybe having a mechanic do it is prudent? What do you all think? Love the input.
Old 06-21-06, 07:15 PM
bridge4d
bridge4d's Avatar
It's a big job. The book quotes close to ten hours labor, and that for an experienced lexus tech. I wouldn't attempt unless you've got quite a bit of mechanical experience.
Old 06-23-06, 06:45 PM
twojayzee
twojayzee's Avatar
If you have to ask about it, I recomend you have it done. Without the right tools it could take you a full weekend or longer.
Old 06-25-06, 08:03 PM
ken8817
ken8817's Avatar
thanks for the feedback
Do you know if any of the additives for filling the cracked gasket work?
Old 06-26-06, 06:22 AM
twojayzee
twojayzee's Avatar
You should always replace the gasket anytime you remove the head. If you have scratches in the block or head they need to be decked flat.
Does that help ?
Old 07-01-06, 08:37 AM
ken8817
ken8817's Avatar
Thanks but on closer inspection the coolant leak is at the back of the engine but not a gasket it is simply where the heater hose goes from the water valve back into the engine. Much cheaper fix.
supraclay
Performance & Maintenance
01-30-12 07:12 PM
NCis300
IS - 1st Gen (2001-2005)
08-19-11 02:09 PM
ken8817
06-29-06 08:24 PM
Quick Reply: change head gasket 93 gs300
