GS Tranny lock
Ok so my brothers tranny locked on his 93 GS and now his brake lights don't work. I've tried everything and its pissing me off. In my 02 IS300 manual it says the brake lights will stop working if the tranny is locked, is this so for the first gen GS too. If yes, how can I get them to work again?
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
![](https://www.clublexus.com/gallery/data/500/Shift_Lock_Override_Button_Cover.jpg)
Just pop the cover out by sticking a small flat tip screwdriver in the slit in the middle and pry it out. Then push down, with the same small flat tips screwdriver, on the lever/button inside. You can now shift into gear. At least you can drive the car.
Good Luck,
Will
TGunz941
Performance & Maintenance
11-22-15 08:27 AM
rajah996
12
05-10-02 09:01 AM
