Every one with 19" Staggered fitment
Thank you very much mic123321 You have helped alot! Can you tell me why all the shops tell me to do a 275x30 instead of x35 in the rear! Because i rather do a 35 also!
Loves Snickerdoodles!
Becuase if you went with a 35 in the front and a 35 in the rear, you'd have a mismatched set. If you were to go with that set-up, you'd have a taller tire in the rear than in the front. 35 in the front and 30 in the rear is a better match, speaking in terms of rolling diameter. If you were to got 35 front, 35 rear, your rear tire would be an 1" taller in the rear and that would look kinda weird.
it really doesn't sit an 1'' higher, more like an 1/4 in. higher, you can't really notice it. i was told the same thing by the shops to go with the same set up, but hell i'm a college student i don't have that much money. My car rides good and i hardly feel any bumps, so thats all that i really care about.
But, El Cap's set-up is different, he's talking about a 275/35 not a 245/35.
Here are tire size charts from www.tirerack.com. You can see for yourself the rolling diamters of the tire sizes in question. You will see that a 275/35/19 is indeed almost 1" taller than a 245/35/19
I have high-lighted the tires in question in red
![](https://www.clublexus.com/gallery/data/500/tirerack.jpg)
As you can see, 245/35/19 and the 275/30/19 are better matched in terms of rolling diameter - 25.7" and 25.6" With the 275/35/19 you end up with a rolling diameter of 26.6", therefore making it about an 1" taller.
sojah
10-05-10 09:24 AM
ems
Wheels, Tires & Brakes Forum
03-23-06 01:44 PM
