Every one with 19" Staggered fitment
Old 08-11-06, 10:57 AM
El Captain
El Captain's Avatar
Default Every one with 19" Staggered fitment
What size tire do i want to go with.I want a good ride and the gutters are like grand canyons were i live so i want a god size that wont rub and i just put a Eibach pro kit on also, just today Infact so i want to order wheels ASAP! Thanks ahead of time you guys have allready helped me so much!
Old 08-14-06, 09:43 AM
El Captain
El Captain's Avatar
Were is the Love? All I want is some tire Sizes?
Old 08-14-06, 09:52 AM
nate579
nate579's Avatar
What's the width of the rims. I think the fat setup for 81/2x10" is something like 245/40-19 275/35-19. But you best do a search in the tire rack forum. They have all the answers.
Old 08-14-06, 10:51 AM
Seize
Loves Snickerdoodles!
Seize's Avatar
Default ..
We can't help you if you don't post your wheel specs. Let us know your widths and offsets and I'm pretty sure we'll be able to help you out
Old 08-14-06, 02:29 PM
El Captain
El Captain's Avatar
Sorry i forgot? Wheel size 19x8.5 front/19x9.5 Rear. Off set is 38mm front and back! And then i just lowered it 1.2" with the eibach pro kit!
Old 08-14-06, 03:09 PM
El Captain
El Captain's Avatar
Does anyone run a 245x35R19 front and a 275x30R19 Rear?
Or do i need to go 265x30 in the rear?
Old 08-14-06, 03:10 PM
GSteg
GSteg's Avatar
those tire should be fine. I have that setup right now, well not on the car, but my tires are mounted
Old 08-14-06, 03:13 PM
El Captain
El Captain's Avatar
Is your car lowered at all?
Old 08-14-06, 04:34 PM
sqwerz
sqwerz's Avatar
Haven't really posted here often, but I run OEM Supra TT wheels. Tire sizes are 245/40/17 in front and 285/40/17 in the rear. Ran this setup for a while with cut eibach's and never ran a problem with rubbing or alignment issues. Hope this helps you out.
Old 08-15-06, 07:06 AM
Seize
Seize's Avatar
Default ...
That will work
Old 08-15-06, 08:43 AM
El Captain
El Captain's Avatar
The 245x35R19 front and 275x30R19 rear will work? Just to be specific! And do you think this size will still ride nice?
Old 08-15-06, 09:36 AM
Seize
Seize's Avatar
Default ...
265/275, you can go with either one since your offset isn't too aggressive. If you want to play it safe, 265, it'll allow for more clearance where the tire meets the fenderwell, that is of course if you're worried about it rubbing. As far as riding nice, not too sure, it's definitely not going to feel like your stock 16"s. I had 20"s on mine with Eibach Pro springs and to tell you the truth, the ride wasn't all that bad
Old 08-15-06, 01:58 PM
El Captain
El Captain's Avatar
I need a for shure answer! Is there any one on here that has the same set up! And i would like to go with a 35 series in the rear but iv been told its not recommended!
245x35R19 front
275x30R19 Rear
Old 08-15-06, 06:56 PM
sqwerz
sqwerz's Avatar
In terms of riding nice, I dont think so. I had 18" Roja's Formula 7 with a 35 series tire and it was terrible;rough rough rough, Well at least here in NYC. I bent every rim, cracked one, replaced at least 10 tires in two years and had no choice but to remove them and install something near to stock. Just my very expensive experience.
Old 08-16-06, 12:22 AM
MIC123321
MIC123321's Avatar
i have 19x8.5 with 235-35-19 in the front and 19x9.5 with 245-35-19 in the back. To be real this set up rides better when i had 18s in my ride and i also have the eibach pro-kit spring.
Quick Reply: Every one with 19" Staggered fitment
