Wheel offsets again
Old 08-22-06, 08:46 AM
twojayzee
twojayzee's Avatar
Default Wheel offsets again
I have read a bunch of posts but cant find the one that talks about wheel sizes and offsets on the first gens.
Right now I have the konig tantrums 18x9 I believe they are +40mm offset.
I love the way they fit. Perfect. No rubbing.
Im looking at doinga 18x9.5 but they only come in a +35mm offset.
What are you guys running ?
Old 08-22-06, 08:56 AM
Kaiser
Kaiser's Avatar
18x9 34mm 18x10 35mm. I may have those backwards but it's only a mm.
Old 08-22-06, 09:12 AM
twojayzee
twojayzee's Avatar
Post up the pix of your car again. If I remember right it looks great.
Whats your clearance like ? My car is dropped around 4" on the Tein Flex's
Old 08-22-06, 10:33 AM
Kaiser
Kaiser's Avatar
https://www.clublexus.com/forums/sho...d.php?t=218326
Old 08-22-06, 10:54 AM
twojayzee
twojayzee's Avatar
Thats not even the car I was thinking of. Looks good, I just wonder how much clearance you would have if it were dropped another two inches ?
Old 08-22-06, 10:59 AM
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
19X8.5 (+23 offset) and 19x10 (+15 offset) The front could be +18.
Old 08-22-06, 11:09 AM
twojayzee
twojayzee's Avatar
First off im very confused about the offsets. I thought I understood. I thought the more positive offset you have the more the rim stuck out ?
LexAristo yours appear to tuck ? My +40mm are within 1-2mm of being flush with the fenders.
So does that mean if I get the +35mm they would tuck +5mm more than my current setup ?
Second Whos the hot girl in this pic ?
Old 08-22-06, 11:25 AM
Seize
Loves Snickerdoodles!
Seize's Avatar
So does that mean if I get the +35mm they would tuck +5mm more than my current setup ?]
The lower the offset the more the wheels stick out. Of course tire size, fender mods and other factors play a major part when working with very tight tolerances and low offsets.
Old 08-22-06, 11:29 AM
twojayzee
twojayzee's Avatar
Originally Posted by Seize
The lower the offset the more the wheels stick out. Of course tire size plays a major factor when working with very tight tolerances and low offsets.
Ok so I was right in my thoughts. The whats up with LexAristos +23 & +15 ?
Why dont his wheels stick way out ? I have +40 right now and they are flush.
Old 08-22-06, 11:31 AM
twojayzee
twojayzee's Avatar
Heres a pic of mine
Old 08-22-06, 11:32 AM
Seize
Seize's Avatar
He has sligthly pulled/flared fenders in the rear allowing him to accomodate his wheel and tire set-up.
Old 08-22-06, 11:33 AM
Seize
Seize's Avatar
Default ...
Heres a pic of mine
I can see your fenders aren't rolled. Rolling fenders makes a whole world of difference when wanting to accomodate a more aggressive offset.
Old 08-22-06, 11:37 AM
twojayzee
twojayzee's Avatar
I didnt roll mine yet cause I havent needed to. These are only 18x9's with 265-30-18 front and 275-30-18 rear. They tuck. The only time they rub is going into my driveway when I stuff one of the fronts into the wheel well.
So I guess the moral of the story is that I can do the 18x9.5's with the +35mm offset and I should be good to go.
Old 08-22-06, 11:39 AM
Seize
Seize's Avatar
Default ...
Here's a few pics of my car for reference
20 x 10 et +38 (rear) on a 285/30/20 Bridgestone S03
This is before I had my fenders rolled. If you look close enough you can see where I was rubbing. As you can see without modding the fenders, the fitment is really tight
Here's with rolled fenders. You can see how much more clearance I actually gained by rolling the fenders.
Old 08-22-06, 11:40 AM
Seize
Seize's Avatar
I'm pretty sure of it
Quick Reply: Wheel offsets again
