My Car is acting up
Yesterday bright n early in the morning i jump in my car to try to start it, I hear CLICK CLICK CLICK. Wont start, so i turn all the accessories off, still CLICK CLICK CLICK. I'm bout to panic here because i'm running late i gave it another shot, it clicked and then started right up.
8 hours after my car was sitting after work, same thing. I know my alternator is going out but maybe because its starting to get cold up here in minnesota so it could maybe be my battery too.
So last night, i connected a battery charger to my car, 2 amps, went all night. SAME THING HAPPENED!!
I'm starting to think it could be my starter?? Any ideas? Similar experiences?
EDIT: Check post number 10 for different issue
The ground from the battery to the frame may be corroded on the inside. Mine was. I couldn't tell until I cut it open, the copper turned into white dust. Next time that happens, put jumper cables from the negative terminal of the battery to the lift hook attached to the head.
My swap wouldn't even start till I did the jumper cable trick. Just click.
That may be but i bought a set of ground wires from ebay...they were cheap but still should work.
I'll add another piece to the puzzle....a confusing one. If the car has been running in the past 2-4 hours approximately, it starts just fine.
Sure got me scratching my head
I had exactly same symptoms last year. Phoned my local dealer (I was late too
and their diagnosis over the phone was bad starter. Got starter replaced by the delear next day. And have not have any problems since. Paid around $400.
Still doesn't make sense on why the car starts and doesnt depending on when the last time it was driven. Also, if the starter went out, wouldn't it not start period?
to be honest ive never had that happen in my lexus, but that happened in my Dodge Caravan about a year ago, and it was the alternator, it gave up on me in a publix parking lot, and eventually it cranked back up,after aout TWO HOURS of sitting, but we still got it replaced just to be safe
Sounds like u have a starter problem it is a very intermittent problem if you can try to knock the starter with a screwdriver or something when u have the problem depending on how bad it is it should start ....Infamous Toyota issue with starters
Get a small digital meter, read the DC voltage across the battery when it will and won't start. When it starts, what's the alternator output voltage.
Let's eliminate the guess work.
Like Kaiser said, it could be my ground, i cleaned out the minorly corroded connection and see what that does for me tommorow.
Heres another issue i have. When my car is cold, it starts out at 14.1 14.2 volts. It starts squeeling, like a chirping noise and after about it warms up 1/4 it goes away. This only happens in colder weather. But then when it warms up, hovers around 13.6 until i press on the brakes.
I know its the belt thats squeeling and it skips in its track but doesn't explain why the voltage is HIGHER than it is at lower IDLING. The Accesory belt got replaced not too long ago. How can i get rid of this HORRRRRRRRRRRRIBLE NOISE!!!???
My experience was that the starter failed somewhat gradually, meaning that it would start fine sometimes and then not start at all in the same day. My brother could manipulate the ignition switch to make it start, but within a few hours one day, it went from startting fine to clicking and not cranking at all.
Again Im not an expert (with cars)
This is happening to me too. I figure I will replace the starter pretty soon, Ive replaced my ground wire, and I have an Optima battery so theres no corrosion, So Ill get my uncle to help me check the solenoid sometime soon, and if thats not the case Ill get a new starter and just replace it myself.
