Brakes
Help
Found a stress fracture in my front brake disc so need a change.
Can anyone recommend some up graded brakes for my GS300 1994
Heard good things about black diamond.
Any advise peeps.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Any advise peeps.
you will need...Calipers, Rotors, brake lines if you want, and pads. Depending on where you get your calipers you may need the hardware for the calipers such as fit kit, shim kit, and pins. There is a write up somewhere here. Search it. Keep in mind the wheel clearance.
*edit: Here is the write up.
https://www.clublexus.com/forums/sho...t=supra+brakes
