9006 for the high beam
9005 for the low beam
194 led for the citylight
standard signal bulb, but I switched it to led dont know the number but Ill check but it is the same on on the GS300 lights...
Yeah you guys with aristo lights in the states will be blinding oncoming traffic due to the light refraction. You can get stick on patches that block that light or cut some tape to stick over the section that angles the light at the oncoming traffic. http://www.aer-net.co.uk/sdc/headlamp-conversion.htm gives you instructions on how to temporarily deal with the problem
The way they come on the Aristo is when you turn on the ignition or car the city light will come on and stay on like the IS300 if you want to do it this way just look for an accesory that comes on with the ignition switch and tap into that
what kind of bulb u are using? that's awfully bright for a 194 bulb... I got 12 LED 194 bulbs from japan and they dont look as bright as yours either... c''mon! share the secret!
