who has switched to aristo headlights?
Just picked up a set cheap on ebay, and i was wondering how you guys wired in the extra "city" light, i was figuring on just wiring it into the outer marker/turn signal bulb wiring.
You guys have any pics?
The way they come on the Aristo is when you turn on the ignition or car the city light will come on and stay on like the IS300 if you want to do it this way just look for an accesory that comes on with the ignition switch and tap into that
are these the same thing? They say Aristo, but they have the orange corner lens. http://cgi.ebay.com/ebaymotors/93-94...41212313QQrdZ1
do you guys ever get flashed? because the cutoff/step for those should be opposite of USDM. I would think you would be blinding oncoming traffic here in the us.
I like the way they look tho.
btw JPGS300 nice gs.
Those on ebay are USDM headlights not JDM.
Those headlights are to the GS300 not the Aristo. The Aristo ones have verticle lines all the way to the end of the corners and the corners have a molded piece that sticks out kinds like a clear reflector.
HEY WHAT BULB ARE YOU USING? IS THAT A 194 LED?
im jelous can some1 show me how to do them???
what accesory did you tap into? and what 4 bulbs did you use from signal to high beam? i have a set on the way!!!
I believe there is a difference between the JDM kouki and Zenki headlights, I brought a few sets over from Japan for friends. wireing is easy, you just tap into the constant side of your parkingor corner light, or you can just run it back to the ignition ... post up more picks ! ! ! !
9005 for the low beam
194 led for the citylight
standard signal bulb, but I switched it to led dont know the number but Ill check but it is the same on on the GS300 lights...
