Rear passenger window will not roll from same door
What's up guys, did some searches and couldn't find what I was looking for. Well here is my problem, my rear passenger window will not roll from its door. I am able to roll it up and down from the master swith. I swaped the switches thinking it might be a bad switch but it worked when I swapped it. Is there a seperate fuse that controls that switch or do I have a bad relay going to the master switch?
Thanks guys,
- b
Thanks guys,
- b
Are you saying that when you swapped switches it started working?
If so I think you answered your own question: It is a bad switch
Not sure I follow you.
There is no seperate fuse for individual doors. There is no relay for switches as the relay is made internally in the switch.
Last edited by justfixit; 11-08-06 at 06:34 PM. Reason: Forgot to post additional information
05ls430518
02-26-18 08:40 AM
