"TRAC" light comes on and off often??? HELP!!!
I drive a 93 GS, and when I start it, the "TRAC" light is not on, but while I am driving, the light will come on and stay on for a while, or just come on and off real quick. But it happens everytime. Has anyone else had this problem, or know what this might mean??????
Did you guys check your error codes?
I also have the same problem, but with my case, once TRC is on, it stays on until I'll restart. Sometimes both lights are on. (TRC off/TRC) Pulled a error code from the ecm... It was a throttle body position sensor, the smaller one. Didn’t change it yet.. Its only a problem when you floor it on slippery surface.
You first need to check for ABS / TRAC diagnostic codes. Look under hood for the diagnostic connector. Jump terminals E1 - TC
Under the connector cover it will diagram which pins are E1 and TC
I would be willing to bet it has a TRAC code of 43 and ABS code of 54
This is the most common TRAC malfunction. It indicates the trac pump motor running too long which is usally caused by a small brake hose leaking underneath the brake master cylinder that connects to the trac pressure accumulator.
Post you codes and lets see.
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
Sasakura, for what it's worth, I continue to have the same problem as you, and I think I replaced the host that "justfixit" is referencing. Look at this pic here: https://www.clublexus.com/forums/sho...t=connector+R3
I think it's the hose on the left. Part # 90947-06009 for a pressure host, list $68.75, net $57.29 and Part # 90301-13011, quantity 4 of Orings list $5.93, net $5.93.
Am I correct "justfixit"? Are we talking about the same hose?
Thanks,
Brian
Thanks,
Brian
JDMCelsior
02-07-08 04:35 AM
MRLUCKY
07-19-07 02:16 PM
