Aristo Powah new dyno #s
Went back to the dyno today after running disappointing #s last Thursday. Took a roadtrip this weekend to the Drift Fury 4 event in Atlanta and found the problem. Believe it or not, my rear wheel alignment was sucking up over 50whp and 70tq b/c of the tires scrubbing. I figured this out b/c I lost almost 100 miles off a tank of gas (usually get 375 on this same trip, this time I got barely 300) and the rear wheel wells and rear bumper were covered in tire dust by the time I got there.
I run a very aggressive toe in in the rear, and boy was it hurting me. I re-aligned the rear toe to stock specs for the trip home, found my lost mileage and the car just felt like it rolled smoother. As i thought, it made a big difference in power too.
The proof is in the #s.. both at 14psi, stock GTE, K26 twins
Old #s from Thursdays pass 292whp, 247 tq
new #s from today 354whp 343tq
A/F is still little rich for this motor and that boost..running sub 12:1 the whole way across...at least it is safe
I'm happy. She pulls like a beast, breaking traction at part throttle from 8psi on up.
Now for that GReddy BCC so I can turn it up and bring these turbos to life.
I wish we lived closer so I could see what a 350hp GS feels like.
Loves Snickerdoodles!
Looks like you're pulling some very good #'s ...and to think, just by adjusting something as minor as the toe, you'd be able to free up that much power. That's amazing
what I notice right away is how nice and rich your graph is at tip in compared to mine. Also, the difference in power between 2nd and 3rd gear is very different. I think there was like an 8hp difference in mine and 60hp in yours. You also had the brain for the sniffer pretty close to the tail pipe as there is very little delay in the lean spike for the shift. See if you can get the winpep files so I can overlay them. I'll try to get down and redyno at 17psi.
i dont use a sniffer (o2 sensor) like you normally see.. we have a copper 1/4" tube about 3' long and run it up the exhaust as far as you can get it. in mine it goes pretty far, so i dont have to account for much variance in o2 readout.
on another note.. worked on the car today.. fixed a few things, coilpack wire (clip snapped off.. thankfully i had a spare harness) and i swapped in the Champions. I was taking a small roadtrip with a friend tonight to NC so I figured it would give me a chance to check it out and hopefully it killed the mis-fire i was getting pulling thru 3rd. GRRR. When i pulled the NGKs they were actually all at .028".. i thought i put them at .030" but i guess not. I have had conversations with people from SF that are in the know, and they insisted that the Champions could hold a .035" gap without misfire. Not on my car
So tomorrow i'll pull the plugs again.. i think i'll try a .032 gap.. and then go beat on it to see if it holds out.
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
i think i'm going to drop in the usdm cams one day this week and tweak the cam gears to see if i can pull 370 out of her at 14psi... i always do this.
no, you will have plenty of fuel to run past the safe limit on the JDM ceramic turbos...especially since the person that swapped your car surely added a 255 walbro or tt supra pump. the JDM 440s usually flow test to average 480cc's
i wouldnt go over 18 psi on pump (93) gas though.. and i surely wouldnt go over 1 bar (14 psi) on the jdm ceramic turbos.
I updated the dyno sheet to a clearer copy for all you guys. Right now I'm in the middle of swapping out the JDM intake cam for the USDM 6 speed cam. Increases duration by 9* and lift by .33mm.. these are small gains to be sure, but i had the cams laying around. I'll post another dyno when i go back..prob later this week.
okay, the USDM cam is in. Champions are gapped to .032" now. AND.. it's raining and foggy as hell.
I still took it around the block to get the ecu synced up again and relearn. I tried to jump on it a bit, but on the wet road i cant get past 10psi before the back end wants to step out..even at 60-70 mph. That is a good sign, but it also shows you how bald my rear tires are..LOL
Tomorrow is another day
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
