I just found out that my rear main seal is blown. At 142,000 miles, I guess it sounds normal. While they are working in that area, is there anything else that can be done, any routine maintenance?
Thanks,
Jon
I had a major service two years ago when I bought the car, but I don't have the records with me at work. I'm sure I would have had it changed because the history was mainly unknown.
There is a screen in the trans. You can have them pull the pan and inspect for excessive debris on the magnets and clean the screen. That would be good maintainence.
Thanks,
Jon
i would recommend replacing:
*transmission front seal
*engine rear main seal
*trans. pan gasket
*engine rear main seal housing gasket
