MAF cleaned, car now stalls...
Hey guys. I just cleaned my MAF sensor with CRC cleaner and now my car stalls when i starts it up. It stays on for a while, revs up high, then low, then cuts out and dies. Did I mess the MAF up? I literally sprayed the inside with the CRC and almost drowned it cause there were soo much build-up inside of it. Did this ruin the sensor? It's cold here in Minnesota so I thought that maybe that caused the fluid to not completely dry causing the sensor to malfunction. ???? Please help. This is my daily driver.
I just did a dianostic test because my CEL was on, and indeed the MAF sensor is dead. I got a code 31, air flow meter signal. I guess some parts just don't want to be clean and rather be left alone. Huhhh...or it could've been the CRC product. DAMN CRC...
mine did something similar, i cleaned it w/ some brake cleaner i think. The car kept stalling after idling for a bit, i found that running the a/c kept it from stalling, so after trying to figure it out for like an hour i just took it out on an empty road, and floored it revving the hell out of it and the problem was solved.
tonynca
Performance & Maintenance
14
08-02-12 06:28 AM
Allaretake
06-03-10 02:36 PM
