Aristo swap questions...
Old 01-05-07 | 12:30 AM
TTSC3's Avatar
TTSC3
Default Aristo swap questions...
I did some searching on this forum and came up with a lot of useful info, so thanks ahead of time everyone. Anyway, I have a '94 GS300 and an Aristo front clip. I've already pulled both motors and the harness from the front clip. From what I read, is this a PnP ordeal, with the JDM harness just needing to be extended...? Is there any additional wiring that needs to be done for the accessories in the car, and the dash/instrument cluster? Infact, is there any addtional wiring that needs to be done to get the car running? I've got a single turbo kit, so the twins aren't gonna be in use, but I just wanted to make sure of anything else I was gonna need to do to get the car up and running. Any advice/tips is greatly appreciated. Thanks guys!
Old 01-05-07 | 01:51 PM
Kaiser's Avatar
Kaiser
Pm Sent.....
Old 01-08-07 | 06:57 AM
mamurra2's Avatar
mamurra2
I also went straight to a single so I dropped my GTE in with everything off the exhaust side, it made lining up that motor mount and dealing with the heater hose a bunch easier.
Old 01-09-07 | 06:37 PM
1jzaristo's Avatar
1jzaristo
hey kaiser would u mind sending the same pm. cause ima bout to do the same swap....need advice!...thank you!
Old 01-11-07 | 09:31 PM
twojayzee's Avatar
twojayzee
If theres something worth posting lets see it
step2me
10-30-18 04:00 AM
EvosSti
Performance
14
10-11-18 05:58 PM
Krednjen
Performance & Maintenance
07-26-15 01:48 PM
Mnguyen600
04-22-15 07:47 PM
Automan
13
11-04-13 02:07 PM
