JZS147 swap thread
#211
So just as an update, I found a GS (on here) that had the GTE/V161 swap done to it. Currently, the car is missing a motor and transmission so i'll be dropping in a GTE VVTI motor and a R154 in the near future. Only reason why I'm going VVTI is because those motors are $1000 cheaper and I'll just take the car to someone else to have it wired. Mechanically, there's no other differences between installing the None VVTI and the VVTI motor right?
#212
As shown in my build thread, its just wiring that you have to really deal with. But the throttle body setup is a bit different than the older models and are more complicated and harder to get working perfectly.
#214
Ok...I'll bite and resurrect this...read through it all and i cannot find anything specific to the 96 gs300. I have a 96 gs300 and an aristo 2jzgte from the same. I have the harness and ecu from the aristo gte. I'm searching for the body plug conversions so i can plug the engine harness plugs into the dash/body plugs.
#215
Sorry for not having responded sooner, I was locked out of my account for quite some time.
you can find the aristo wiring information here http://wilbo666.pbworks.com/w/page/3...ngine%20Wiring
The electrical wiring manual I have is for a 1995, but that should be close enough to be the same. I will reply to your pm with a way to find it.
edinburger
11-29-13 10:06 AM
cardwielde
Performance & Maintenance
11-09-09 10:23 PM
motorheaddown
04-02-04 04:24 AM
