JZS147 swap thread
#63
Like kaiser said
The aristo is plug and play. The usdm stuff will work but its a pita to do all the wiring conversion
#66
#2. You can not use the GE clutch and fan assembly. The fan will hit the top water neck. You can use a TT Supra fan assembly, or can use electric fans. Buy a new water pump from Toyota-be sure to get the front half and back half. I paid $130.
#67
Ok, that straightens things out. I replaced the water pump on the gs recently and thought I might be able to get away with using it, but I guess not. Would you guys recommend to just get an oem supra radiator or to step up to an aluminum one? I am thinking of going bpu right away and upgrading some things, so I'm wondering if there will be any benefit there.
#68
If going electric fans, yes upgrade the radiator. I have a Griffin radiator and I ran a little bit hotter than I liked when the temp was over 105 ambient. I'm going to relocate my trans cooler from the condenser and I think that should cool it down enough.
I have a tt clutch and fan sitting in my garage I'm not using. I was going to put it on but never got around to it. I would have had to rearrange my intercooler pipes. Let me know if you need it.
#69
94 gs300 aristo swap
hey guys i have a couple questions here for u. i bought a 1g aristo front clip and have torn it apart already. while i was refreshing the motor i ran in to a problem the water pump i ordered would not match up with the water line on the block. bolted right to the block but was about a inch short of the water line then i also noticed that its thermostat housing bolts were in a different angle and the upper pipe didn't have the pipe of the water pump going to it. so what should i do. otherwise the project is going smoothly so far. ill get some picks up this week if i get a chance. also if any of u are local that have done this swap that would be awesome.
for what i no the water pump i orderd is a 93 supra tt
#70
Former Sponsor - Cancelled
If you do want to do a swap from a different car, you can, but the wiring would need to be converted. We provide this service:
http://www.phoenixtuning.com/
But with Aristo 2JZ engines being so abundant, they are the logical choice. I will probably swap a VVTi 2JZ into my '93 GS300, but that's just because I like being difficult
-Doc
#71
I just did this and took pictures so everyone could see how to do it. It was very very easy and took about 20 minutes.
first remove the gauge cluster completely
#74
Here is a close up. I used a little zip tie to keep it tight after twisting the wire on with a set of small needle nose pliers..........then but it back in and your good to go. RPM gauge works perfect............
chris w
chris w
#75
Engine Swap
I have a 1994 GS 300. I want to put the 2JZ-GTE in it. I want to know everything that I need to know to make this happen. Can someone tell me how much money Im going to need and exactly what parts im going to have to buy. Thanks
