JZS147 swap thread
#121
My intercooler isn't mounted yet. but it's going behind the crash bar.
get an electronic boost controller. you can do 10psi I think on stock motor, need a boost cut controller for more.
Safc is a good setup. I'm going to eventually be doing a writeup on a full Aristo fuel system setup for 550+ rwhp cheap and easy.
Jeff
Jeff
#123
If we were able to help just one person it was worth the effort. There was a whole lot of input from a whole lot of people so really the community is responsible. Thanks tho.
#124
Hello i purchased a 93 lexus gs300 and it runs really strong/smooth.... I was told from previous owner that the engine had been swapped prior to my purchase and it currently has 80k miles on engine... How would i confirm that engine indeed has been swapped/replaced?
#126
yes ive hurd they do last, thanx...the odometer reads 220k. but i was told engine has been swapped and currently has bout 80k... so theres no way of knowing at all of an engine swap. thank u.
#128
What did you guys do about the ABS brake unit?
Im almost done with my swap, but the ABS brake unit is hitting on the stock twins.
Does everyone go Single turbo or remove the ABS?(Im assuming)
Id want to keep the ABS. Is there any shops in SoCal, that can do this service, at a reasonable price?
#133
the GS300 fan shroud won't work in the 2JZ-GTE swap. The water neck doesn't like up with the Supra TT rad. I just used electric fans, and since the GS300 is wired everywhere for electric fans, it's a piece of cake to wire them in, they already have three locations to mount them, in with relays already there, etc. And my car never overheats in the hottest North Carolina heat, and I have to turn the fans OFF in the winter, as it never comes up to operating temp.
Plus it has a nice clean engine bay.
I use a 10inch fan and a 12" fan (10 on driver's side, 12 on passenger side)
so it would clear my intercooler piping. (It' MIGHT have been an 8" on the driver's side)
Jeff
Jeff
#134
Jeff
Jeff
