Brake experts! Need replacement calipers
#32
I looked all through the Shea Stadium salvage yards, and I can't find any Toyota / Lexus vehicles with the 4 piston calipers, so I just replaced my front w/ Autozone rebuilds and repainted them black. I noticed there isn't any more clunking either.
#33
Hi.... im a newbie to this forum. this look like it was an old thread. but i aslo have caliper issue. everyone talkin about swapin from a LS400. im sorry if this was already answerd, but what year LS400?
#36
What year 4 Runners can be used also? Have to keep my eyes open on Craigslist LOL! I won't find anyone parting out a GX470, they are too new and if you find one hit, they'll sell the car as a salvage car.
#37
Hey guys,
Quick question, I'm having an impossible time finding TT calipers and i'm not spending 400 per caliper form toyota... I need to know if I can use LS400 calipers with TT discs, I dont believe i can because they are too thick right?
#38
Alright, I'm bringing this thread back. I just got a full set of Supra TT brakes, front and back for my 1st Gen GS. My question is what to do with the dust shield? I don't want to remove it but do I only trim where the Supra TT calipers going to be at or elsewhere? My other solution is can I use the Supra TT dust shield if possible. What I mean is if I have the Supra TT dust shield, does it bolt on directly or need modification? Oh, what about the rear Supra TT brakes? Do I have to do the same thing? Any help would be appreciate. I know it's kinda sad that I have 93 Supra TT but don't want to remove the wheels and check it out, but rather ask here since I know it's one of the most popular mods for the 1st Gen GS and SC.
#39
Congrats on your purchase of the TT Calipers.
You can eyeball with some cutting shears and cut off what is need on the stock GS backing plate (dust shield). DO NOT cut off the cooling duct obviously, you don't have to cut out much.
You CAN use the Supra dust shield, but it will be labour intensive to remove the bearing from the hub (you need a press to press out the bearing, you may as well get new wheel bearings, seals, C-clips if you're going this route.
If you have any questions, post here or PM me.
I did the TT caliper upgrade on my Aristo a couple months back, stops great BTW.
#40
2JZ147, thank you for your help. It's good to have someone with expierence on this mod to give advices vs. guessing what to do as you go along. As for the rear, is there anything I need to do vs the front? I search the forum, and found out the Supra TT rear does not fit for the 1 Gen LS because the length for bolts are not the same. What about our 1st Gen GS? Thank you once again.
#41
#42
Thank you once again 2JZ147. It's good to hear that the rear TT calipers fit with no problem. I guess the toughest would be the front due to requires shaving the dust shields. With all the infos in this thread, I'll try to put on my GS sometime next week. Hopefully, everything will go smoothly. If there's anything else I need to know, please inform me now so I don't have to go through other people mistakes.
#45
Well, I tried to do the swap today, but no luck I found out late that my 18" L-Tuned wheels does not clear the Supra TT front calipers. After hours of jacking up the GS, loosen all bolts for the calipers, removing all four wheels, and shaving one front driver side dust shield, I have to put all back due the front wheels won't clear. I was going to shave the front passenger side dust shield also, since I was going to stick with the modification. I was thinking of doing the rears for today and finish up the front some other time, but after four hours in the sun by myself doing this project, I was too exhausted and my body was in pain, especially my hands for trying to loosen all the bolts. Thank God, I have the tools to for it. My recommendation for this project is to do it in the shop where you can work standing, not bending down as I did. Either way, I'll try to finish this project up. I have to, especially seeing the Supra TT calipers on my GS for a short time. At the moment, I'm planning to go with spacers, but ultimately, I'm going to find wheels that will clear it so show off the Supra TT calipers.
