supra coilovers on 1st Gen GS - has anyone had success
Old 03-20-07, 10:15 AM
twojayzee
twojayzee's Avatar
^Same here, same rig even ^
Old 03-20-07, 11:53 AM
nyARISTO
Sunroof Surfer
nyARISTO's Avatar
Originally Posted by zazzn
ny i just did... so why are they listed as the same part number then... thats strange so we need a longer rear... hrm.
WHat about GS300 gen 2 coilovers?
I really dont know why they are the same part# but i didnt even think they would fit on a supra if i took mine off but when i looked it up back then and even now there still the same part # www.tein.com
Old 10-10-07, 09:56 AM
Aristo-cat
Aristo-cat's Avatar
did a search and I wanted to bring this topic to life again.
I just purchased Stance coilovers (front 2nd Gen, rears MKIV) and I noticed that someone on here said they needed to modifiy the lower mount to compensate for up travel.
I guess i'm just having a hard time visualizing what he's talking about. If the shock body was too close to the wheel, wouldn't a wheel spacer be more "easier" to do? And also, the recoil on aftermarket coilovers are not the same as stock so I wouldn't think the the distance of up travel would need to measured the same as stock.
Anyway, i'm not too concerned about this since the entire body of the shock is threaded and I have wheel spacers. I was just trying to figure out the logic.
Old 06-01-08, 01:47 AM
butcher
butcher's Avatar
Originally Posted by SuprRunner
wow, a lot of different views here.
I was always under the impression that the fronts fit, but the rears were too short. There wouldn't be any problem with fitment other than just too short.
Anyway, this is what "I" found out.
Yes, the fronts fit just fine.
The rears work with no modification as long as you want to run no larger than stock tires, and don't go over a single bump. There is absolutly NO up travel. They would make a lot of noise and could possibly do some damage if you drove on a bumpy road for too long.
So here is what I did:
I cut the lower mounts off the old factory struts, and welded them onto the lower bracket of the coilovers. This made fit PERFECT since it added about 2 inches to the lenght of the coilover and that is about how short they are.
Hi,
I would like to bring this back up again.
I was wondering if someone could show me a picture of what they did in this process? I cant seem to visualize it, sorry.
Thank you.
Old 06-01-08, 07:38 AM
wowitztai
wowitztai's Avatar
Any pictures to show?
Old 02-01-10, 01:25 PM
jdkittle05
jdkittle05's Avatar
anyone have pics of your stance with mk4 coilovers?
Old 04-23-10, 11:43 AM
jdkittle05
jdkittle05's Avatar
I was wondering. Has any one tried to put supra lowering springs on a gs300?
Old 04-27-10, 09:41 AM
cbass147
cbass147's Avatar
What exactly constitutes as being really low in the back? Can somebody please just post some pics of the highest MK4 coilovers will make the rear safely?!
I'm thinking about getting some PBM coilovers but want some pictures first, I want to be close to tucking rim with 18's so I doubt the lack of upward adjust ability will be a huge issue for me.
horent135
05-13-11 08:07 AM
GS300Rich
Suspension and Brakes
54
03-20-09 06:55 AM
Aristo-cat
10-25-07 03:36 AM
Aristo-cat
07-12-07 07:56 AM
SuprRunner
03-11-07 10:18 AM
Quick Reply: supra coilovers on 1st Gen GS - has anyone had success
