tranny problem
anybody out there have tranny problems. Automatic tranny, when starting car
in the morning and then shifting to drive the car jumps. then when driving and coming to a stop the car feels like its going to shut off but then returns to idle. please let me know what you guys think.
I have somewhat of a similar problem too. However, my car hesitates when I initially step on the gas and also at exactly 55 mph. Are you guys sure that it's the tranny that causing this? When stepping on the brake, sometimes my car shakes a little bit too.
You guys that are having jerking and stuff with the tranny. Make sure to check your engine and transmission mounts. At 100K+ miles those rubber components are bound to go out on you. Broken mount = motor and tranny hitting or moving too much when you step on gas or shift into gear.
Changing the fluid and checking that it's at proper level will likely help, although I doubt are the answers to your symptoms.
The newer Toyota Automatic Transmissions today are much more advanced than many, even mechanics, would ever presume. Similar to the engine, using certain input sensors, the ECU will also determine how the transmission performs.... so the possibilities are endless without further diagnosis and/or process of elimination.
What is your RPM when warming up? What is your RPM while idle in "PARK"? What is your RPM while idle in "DRIVE"? If your car feels like it wants to shut off? That can easily be "Throttle Position Sensor" related, which plays a major role in determining transmission outputs as well as idling problems.
Just a hunch..... it seems like your "TPS" is just slightly off adjustment..... if that's okay, check the "TPS" itself and/or it's wiring.
Sensei
Sensei
It was explained to me at the dealer the other day that the transmission mounts on Lexus models of the early nineties are far more flexible than many other cars. The guy in the service department told me that they routinely see cars come in with 300k miles that have no need for such a replacement and that the symptoms I described are normal. The issues I described earlier aren't a big deal by any means; I doubt anyone would even notice but me...so hopefully the service department knows what they're talking about.
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Interesting, this is the question that I have been looking for. I have a 95 GS with over 159,+++ and I notice when I put it in gear it jumps, I thought the mounts that were bad, but I am going to try the tranny flush first. I thought it was just my car. Glad but not happy to here I am not alone.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Sensei![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Sensei
mine jumps only when cold. after its warmed up it's fine. i'm guessing because of the higher rpms when the engine is cold pushes the car making it jump forward when u shift into drive.
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Hey, my car was having the same problem, but it got so bad to the point of now, when i put the car in gear, it does shut off. How much was the part, and how hard was it to change out? I was thinking of buying a different transmission, but if this part can help me not have to do that i would love it.
SuperCoupe400
Performance & Maintenance
07-29-09 04:49 AM
