what do you guys think?
ok i was thinking on going on a swap from my 2jzge to the gte but ive done alot of reading and decided to stick with the stock and mod it up NA/T i have a 93 black on beige with 185,000 well i was wondering how this set up would look good and also if you guys can recomend on me doing any preping before i start this project any help will be taken seriously thanks.
here are the mods i have in mind that i searched all over supraforum club na-t and of course my home here
Front Mount Intercooler (24x12x4)
for manifold needed Toyomoto <<
T67 Turbo (Dave H)
Apexi S-AFC2
HKS VPC
Turbo Oil Line Kit (Dave H)
Tial 44mm External Wastegate
HKS Super Sequential Blow Off Valve
HKS Aluminum Flange
Walbro 255LPH Fuel Pump
525cc Injectors w/ Plugs (Dave H)
K&N 4” Filter
3” Aluminum I/C Piping
Boost Logic 2.5mm Head Gasket
ARP Head Studs (Under Cut)
im very concerned on the manifold part because of the distrbuter is there any other manifold that can bypass this or do i have to hack the manifold to make this work? i may be also looking for some one to install this project since i work full time any one know of a place or if someone know of making this project work pmme with price quote im from nj
T67 Turbo (Dave H)
Apexi S-AFC2
HKS VPC
HKS Aluminum Flange
K&N 4” Filter
Im not sure, but I think the DaveH turbos are for his kit, and his kit comes with a manifold that has a buick style flange. Like I said, Im not 100% sure of this, but if thats the case, then the T67 from DaveH wont fit the toyo manifold, and anyway, the toyo manifold is made for IS300 so it wont clear the dizzy. Like Kaiser said, the 93-95 tranny cant handle more than 325 at the wheels without slamming against the rev limiter when shifting. I think the 67 will be over kill depending on how much power your looking for, if you want somewhere in the low 300-320 range, just go with the T61, it will get you there at 8-10 psi and have a little quicker spool than the 67. But, if your planning on upgrading the tranny and I can see that your getting the 2.5 headgasket, then stick with the 67 and just aim for like 400whp.
thanks abear for the input i read in the supra forum you can get 300~350 at the wheel easy with the na/t without doing a tranny swap is there anyone that has done this in my area nj ny and if yes who did the installation and you are right about it is the t61 i also might want to do the heads im not sure 100% if i find someone out here swapping a 2jzgte i might go that route for a good price but like i stated before i don't have no space to work on cars myself and the time i dont have neither, with work and family. Engine already has 185,000 im not sure if it would be a good idea to go ahead with the turbo i havent found a post with anyone with my milage doing it and if it has happen and if some one has a link to read up on it ill apreciate it i just want to have everything ready just in case it can happen with no problem
there's a guy with a sc300 with high horses and he said that he had over 200,000 on his engine on the club na-t site. Also, even if the engine some how holds up, your tranny with that many miles on it might not hold up for long.
Sunroof Surfer
and as for tranny everyone is diff. i know for a fact that w58's good for 400+ and aliga with his auto stock tranny blew at 490rwhp and thats 22-23psi on a 61.. but tranny cooler would help a little.
Sunroof Surfer
you can allways miss-match manifolds. my manifold is for VVT-i and i didnt even clock it. i have open turbo and sits infront of the distributor
Faceoff im in NY and have installed dosen true turbo's ask around NELOC about me CHECK THREADs... recent turbo install was done in fellow friend and CL mod GSOUP
Go for it
As Tony (NYARisto) stated I'm rolling in a GS VVti NA-T with a T-61 turbo. We nstalled it ourselves. You should be able to mismatch manifolds. Tony is running a T61 in his 1st gen GS just like I am. There's another member here thats SC NA-T and he's running a T67 and i believe he has 160K on his motor.
FaceOff we're having a meet on sunday at Carnarsie Piers in brooklyn. Maybe you should come thorugh if you can and check out the rides out here. There are several NA-T cars that are going to be there.
here's the post.
https://www.clublexus.com/forums/sho...=268315&page=6
here's the post.
Go for it
here's the post.
here's the post.
i might go to this meet sounds very intresting lol man i broke nights reading up on this so many diffrent views and some confusing to understand.thank you guys for helping and posting.
ok this is the thing with my ride i still need rims springs my front driver seat is ripped up pretty bad i need a ashtray some minor body work and new paint i dont know if i should go turbo or do those things first.Im confused on that the paint work will come at the end since im working on a budget lol what do you guys think? i should do say fu*k it and go turbo or do the detailing first?
