Stripped oil pan bolt
Help I think that i stripped the oil pan bolt, i was a dumb A$$ and i think it went in there wrong, better yet i know it did. Any info on getting it fixed? Maybe a machine shop will tap and die it?
You stripped the head? I went to ACE hardware and bought some bits made specifically to get out stripped bolts. I paid $15 for a set of them. Might as well take a good bolt with you to replace the stripped one once you get it out.
Here is the link to Irwin's website. Not necessarily the one you need, but look for a bolt extractor.
http://www.irwin.com/irwin/consumer/...rwinProd100519
If the threads on your oil pan are bad, the least expensive way to repair is to
get an "oversized" self-tapping oil plug that will fit into the larger hole. Self-tapping will create new threads for the larger sized plug. Just search online or get at local auto supply store.
